Winslow said:
The Dealership took a look at my 1990 FJ-62 and wants $1800.00 to replace the knuckles, seals, and hubs. They are, in their words, "shot". Seems like a lot. What is the long term effect on not replacing them? Or waiting another 50,000 miles? It drives fine, except for oil streaked on both rims.
There are some things you can check to see how bad the situation is. Open the fill plug on your front diff (the upper plug) and take a sample of the oil. It should be thick, but still like oil, not like it's been contaminated w/grease.
Remove the square plug on top of the knuckle, and stick a zip tie into the knuckle housing. Remove and smell the grease - it should be grease, with no gear oil smell.
If the gear oil in the diff seems to be contaminated with knuckle grease, or vice vesa, then you need a front axle rebuild. Even if you do need to do this, you'll likely be fine to drive for awhile as is.
If the diff is filled with some really thick gunk, that's clearly contaminated with grease from the knuckle, then drain it, and refill with gear oil. This will prevent damange to your front diff.
Of course, the more you drive every day, the more important it is to do this soon...but you probably have some time to develop a plan, to buy parts at a good price, to find a cheaper mechanic to do the work, to screw up the courage to do it yourself, etc.
If you can find somebody nearby who's done it before, that can "hold your hand" it'll make it very doable.
It's probably worth $1800 for the dealer. The question is what's it worth to you? My first one took 3 long days. My second one took 2 easy days.
HTH
