Ok, I've watched every video I could find on doing the knuckles on my FJ60 and overall it seems like a relatively straight forward job. One area I did have a question on (that I didn't see in any of the videos was disconnecting the brake lines - which seems like an obvious to get the birf, knuckle, spindle etc out).
Can someone confirm that to disconnect the lines I need to disconnect starting at the hardline (using 10MM channel wrench) then just spin off the rubber brake line. Also is it ok to just leave the caliper attached to the dust cover, or it disconnecting it easier in the long run.
Finally, what's best to plug the brake line to minimize the brake fluid from dripping out?
I'm also assuming that the nut on the hardline (attached to the axle) is just a normal counter clockwise rotation to disconnect if I'm looking at the nut (ie from under the car looking out to the back of the dust cover.
I know, probably some dumb questions....but I figure better than making some dumb mistake.
I've got all the nuts soaking in some pb blaster to loosen up anything that's rusty.
As always thank you for your help!
