tighten until it snaps and then back it off a 1/2 turn.
cruiserdan said:I don't really know and I have been thinking about it for a few minutes. The socket is kinda small and I imagine that anything over 35 lbs or so may break it or mess up the end of the stud.
You see when you tighten up a nut or bolt the stress is spread over the face of the nut or head of the bolt. With a stud all you are going up against is the tapered end where the threads end. I can't see that taper taking the full-on torque.
landtank said:tighten until it snaps and then back it off a 1/2 turn.
landtank said:if you're nervous get some red locktite in there. A little heat on the stud will crystallize it if you need to remove them.
