Probably an easy answer, but couldn't find it through the search tool. A bunch of info and pics of the starter and knock sensors, but nothing on the harness itself.
BACKSTORY: So when I had the starter replaced on my truck, I went ahead and had the knock sensor on bank 1 (P0325 CEL) replaced as well. Drove fine for about 100 miles, then CEL turns on again for the same code. Reset it and never came back for another 3.5k miles. Light goes off again today and truck runs on limp mode. Took it back to the mechanic since it was covered under warranty. He tested the sensor wires with a multimeter and said everything looks good, reset the light and told me he would have to charge labor if he has to pull the intake (warranty was just for parts). Safe to say I'm not going back.
Anyway I plan on tackling the job myself to pull the intake and just replace the harness entirely. Mechanic only replaced the sensor itself and used the old wire and harness that's 23 years old and brittle as heck.
I found the harness online and it looks like its a 3 way connector like "Y shaped". 2 that split to the knock sensors, and 1...well that's my problem. I don't know where it goes. I'm trying to do as much research before I pull the intake and running into a obstacle. Here are some pics from other members that I edited that kind of explain my issue.
1. Bank 1 sensor
2. Bank 2 sensor
3. ???? where is does this connector go? do i have to remove the starter to access wherever it leads?
is the 3rd connector underneath the wire looms? or does it connect to these guys behind the starter?
again not my pics....all from other threads.
1. Bank 1 sensor
2. Bank 2 sensor
