@TeCKis300 (Tellurium Carbon Potassium Lexus IS300?) I really like the ease of this. While I'm not interested in turning the 2016 Mom Mobile 200 into anything more than a glorified pavement pounder at this time (unless you can talk her into the Dobinsons MRA I want?), I think the concept rings true for my 80's minimal needs. I like simple, and, if done correctly, the removal of excess redundancy. There's already enough packed away in this thing for my long weekend camp trips, and I've got a lithium jump starter for emergencies. I know it's a 200 forum, but the discussion is applicable and already baked. Only difference I see is smart alternator of 200 vs not-smart (dumb?) alternator of 80.
At first, I was planning on the "proper" dual battery system. Two group 27 AGMs, ACR, maybe a DC-DC charger, see if I can find a place to install a RedArc sticker so the people know, all the jazz. But it's overly excessive for me to power effectively just a 65L dual zone fridge that advertises 0.7 Ah of draw (likely double if I want ice cream in Florida). I've a winch that gets used on every trip (those damn J#@ps), but in all my years I cannot recall a time that I used one without engine running (and at higher-than-idle RPMs). I've put together my comparison spreadsheet, and the cost just seems like I'm getting too Overlandy and exaggerating my needs for "proper."
Fridge has built in auto low-voltage cut:
I'm stuck between
A) Creating a larger bank as you've spelled out here (I've got a battery tray sitting here in my office waiting for me to slap another lead acid in) with continuous power run to the rear
- Would either require a fixed solar system to keep things going while parked for long periods* or
- Simply disconnecting the fridge while the truck is parked for long periods* to avoid draining the battery
B) Just running what I've already got (a single lead acid group 27) with ignition-on-signal-only sending power to the rear power source (tap into a relay or something?)
- This power source will power a power bank (~500 Wh Jackery, Goal Zero, etc.) while driving to power the fridge
- Potential to reduce costs by going with a lower Wh pack - becomes cheapest option if so
- Disconnects truck's power to rear of truck when the truck is off so the power bank does its thing independently with enough juice between alternator charges
C) Running what I've already got (a single lead acid group 27), but with CONTINUOUS power run to the rear with a permanently mounted solar panel
*Long periods = think storage at the house...camp trips are typically a long weekend with exploring each day - meaning alternator will charge for the trip.
All of these options are close in cost between the cost of a power bank vs the auxiliary items needed to make a dual battery system fit/function (sans solar introduction for option A). All will require a power run to the rear regardless (isn't in place for the 80, nor would I want to use a typical cigarette lighter style DC plug for the fridge).
OPTION A | OPTION B | OPTION C |
PROS | PROS | PROS |
| Integrated | Least labor intrusive - use what's in place and just run power to rear | "Forever" power with the permanently mounted solar |
| Large capacity | Portable power source | No need to tap into factory electrical to pull ignition signal |
| No need to tap into factory electrical to pull ignition signal | Integrated inverter, USB, DC, MPPT, etc. | Integrated |
| Cheapest | | |
CONS | CONS | CONS |
| Requires disconnecting the fridge from power to avoid dead battery | Not integrated | No redundancy with a single battery |
| Additional cost to include inverter (nice to have, not critical to existing plans) | Need to tap into factory electrical to pull ignition signal | Most expensive (solar + MPPT > power pack) |
| Potential additional cost if solar is wanted | Potential additional cost if solar is wanted | |
| Most labor intrusive | | |
It's funny looking at the chart. The least expensive option has the most cons. The most expensive has the least cons.
Anyway, if anything, to further the discussion on the ultimate KISS vs slightly less-KISS and avoiding full expo-bro... Curious on your thoughts. What am I overlooking?
Excellent topic. 5 stars. Would discuss again.
