Hi all, I put taller rear springs on and am adjusting preload on my Kings front coil-overs and want to cross check my results.
The short version is that I think I am getting roughly 1/8" of height change per full rotation of the preload collar. Are others seeing similar?
Truthfully, the accuracy of my measurement is iffy and has poor resolution. It could be off by 1/8" +/- and I don't think I'd be able to tell. I've tried to refine it a little by putting a bolt on a rare earth magnet and locating it at the center of the wheel to use as my hub center point. This seems to give me a little more repeatable results. I should try to rig something more accurate up, but I'm running out of time before a trip, so just want it to be close enough.
What is the range of acceptable variance side to side on an axle? I'm off more than I want to be at 1/2" side to side, but I think if I take two turns back out of the passenger side it should get me within 1/4" (but given the accuracy mentioned above, could be off).
To verify, I did run through a drive cycle to settle the suspension before measuring post adjustment values.
I have an alignment appointment tomorrow, so hope to do the "final" adjustment tonight.
