OK so when I first put the King front coil-overs and rear bypass shocks I thought the rear might’ve sat too low when I had the front crank up a full 3 inches.
So I went to OME me springs and a half inch spacer. That proved to be a way too much rake. The truck would look even more ridiculous under braking. Apparently OME severely under rates how much higher the springs are. So I had to decide whether to:
1) Keep OME springs as just remove spacer. This might still be too raked and also the springs are a bit more hash.
2) keep the spacer and put back on factory springs. This would be very close to level and would also have a better ride. But I was a little concerned the rear could end up too low.
Below is how it turned out. What do you think?
