No go with more grinding. I took enough off to punch through on a lower edge. I really can't take more off. With the front and rear cams at neutral to slightly out they clear. In the front I can get to 7, maybe 8 o'clock depending on where the rear is. They are not going to clear the bumpstop at full droop without cutting out a chunk and welding in a patch. Even then I'm not sure the bump itself would fit. I'm officially annoyed.
I feel like clearance got worse after I dropped in the OME UCAs. Probably the stock UCA was limiting some droop. The LCAs are still loose so it is really at full droop.
At this point I think that I'll just get it aligned and see where it is. If I have to pull them back off and weld in a patch I won't be happy, but so be it.
