All done! Test drive to Costco complete!
Tips for those doing the Valley Plate fix in the future:
1. Make sure you order the correct SAIS gaskets (The ones from the Tundra are different). Correct part number for LC200/LX570 is: 17376-38020. I recommend ordering a quantity of 3 or 4 since they are cheap, not usually stocked locally, and prone to bending.
2. Order this long 10mm ratcheting wrench for the SAIS bolts. Trust me. -
https://www.amazon.com/dp/B0CLVPNWRT?tag=ihco-20
3. Order this extra throttle body connector. There is a good chance you'll break it during removal. Watch a YouTube video on "de-pinning." With a small watchmakers flat blade screwdriver, it took me only 10 mins to swap the new connector. -
https://www.amazon.com/dp/B0F1KCZNC3?tag=ihco-20
4. Order this radiator funnel to make your refill much easier -
https://www.amazon.com/dp/B01A2CQSU6?tag=ihco-20
5. Order this to make applying the FIPG super smooth and consistent bead. -
https://www.amazon.com/dp/B007IQ4XWK?tag=ihco-20
6. If you own an LX570, remember to DROP the LX570 into LOW mode before you start. Might as well save your back by making the entire vehicle lower to the ground
