Hi,
I have a 1997 LX450 and after arriving home from a routine oil change last night I can not get the key out of the ignition (the engine turns off), but it stays stuck in the ACC position.
I was finally able to get the key out of the ignition by pushing with some force on the shift lever to the park psoition and then I was able to remove the key. This morning, I again have the same issue and have to push hard at the shift lever to the park position win order to get the key out.
Also, my brake light on the dash has been on for the past few weeks and although, I the brake fluid level looks good and I topped off the brake fliud to the proper level, I brake light remains on. Don't know if this also contributes to the issue with the key problem.
Please can some of you experts on this board give some adivse as to what might the problem be.
Thanks in advance.
-J
Thanks in advance.
-J
