Off Road Wheels | Kansei Wheels
Be ready for all conditions and explore what's past the pavement.
I’m new here and to LC’s as well but the lug pattern is right and the hub bore is right as well.
But the offsets are not (0 and -10).
I have them on both mine and wife's hundies. Went with 0 offset. LX has the AHC sensor mod, flattened pinch welds. BFG KM3 285/70/17.
Land Cruiser has 2.5 OME + 1" body lift, flattened pinch welds, BFG KO2 315/70/17.
No rubbing during normal street drives.
The Kansei center caps will not clear the front hub. Overall, I think they look good and gives the car an aggressive look.
- jackson
Look awesome! Did you powder coat the front hub?285/70/17*
Thanks! No I just cleaned it real good and sprayed it with some gloss black rattle can.Look awesome! Did you powder coat the front hub?
Did you use spacers to clear the front hub? My local shop said there would be clearance issues with 0 offset and 110 bore.285/70/17*
Odd. I tried to install and mine are hitting the hub bolts. Considering 5mm spacers to fix. Just my luck to have mine fit different.Nope, no spacers. They bolt right on as-is and fit perfect but obviously the center caps don’t fit in the front.
I’d be shocked if these didn’t show signs of contact / indentation with the 6 hub nuts on the front hubs.Odd. I tried to install and mine are hitting the hub bolts. Considering 5mm spacers to fix. Just my luck to have mine fit different.
Nice 100 series. How much clearance between the UCA and tire? I'm looking at getting the -10 offset. Thank you.Nope, no spacers. They bolt right on as-is and fit perfect but obviously the center caps don’t fit in the front.
Lots of room.Nice 100 series. How much clearance between the UCA and tire? I'm looking at getting the -10 offset. Thank you.
Do you recall what lug nut size you went with to mount these? Or do the OEM fit? I'm about to order a set myself.Nope, no spacers. They bolt right on as-is and fit perfect but obviously the center caps don’t fit in the front.
OEM won’t work. This is what I’m running.Do you recall what lug nut size you went with to mount these? Or do the OEM fit? I'm about to order a set myself.
