Thanks to all who helped get my new Painless harness and DUI distributor dialed in. It started right up. Went for a long ride and after sufffering some occassional and intermittent backfiring, decided to take it home and maybe retard the timing just a degree. It was running strong.
I went to go start it up and found it wouldn't start , only a cylinder half firing and then dying. Found that my starter solnoid was bad (can you rebuild those?) and replaced it with a gear-reduction unit I had lying around. Now it starts fine, but it barely stumbles along its idle. It will half-heartedly rev up when it is floored (to a max of ~2000 rpm) but will stall or barely idle again when accelerater is let off. It cannot muster enough torque even to roll forward a few feet. It just stalls, even when revved.
The carb was rebuilt a few months ago, but I haven't looked inside yet. Possibly a bad fuel filter??? I'll go replace that in a few minutes, when the garage is slightly more aired out.
Any theories? I will, of course, check the static timing again...
Thanks all
Thanks all
