RET2
Things of this nature are a byproduct of depending on others to do their part of a task as well as you did your portion.
Get the Fumoto valves (pan and drain) and a cold bottle of CM and do your own in 20 minutes. One could also transition to full synthetic and only due 1/2 or 1/3rd as many changes.
Who isn't running full synthetic in their 200 series? Isn't synthetic 0w-20 the standard recomendation from Toyota?
If I had a mill and taps (and knew the right size to use), I'd try it. I don't trust my drill press to drill round enough for an excellent seal.Get the Fumoto valves (pan and drain) and a cold bottle of CM and do your own in 20 minutes. One could also transition to full synthetic and only due 1/2 or 1/3rd as many changes.
I've ordered and received a Toyota aluminum lower screw-on piece...thread hole on that guy is 18x1.5mm but you'd need to mill the surrounding raised rings around the threaded part to use that size.If I had a mill and taps (and knew the right size to use), I'd try it. I don't trust my drill press to drill round enough for an excellent seal.
Only thing that comes to mind (been on a tractor most of the day) would be to haveVery cool. How will u test? Don’t want anyone blowing an engine. I think getting the upper part hooking up some lines and generate typical engine oil pressures. Perhaps Brian has a test rig he’d give you time on. Lemme know if I can help. Watching with great interest.
start the engine while I'm looking for seeping or worse under the truck. If we don't find leaks, I'll leave it running until it gets to normal temp and then another half hour or so. Assuming that 3/8 pipe thread will work, I plan on using This Femco low profile drain plug.No issues with mixed metals or brass threads?...l temp and then another half hour or so. Assuming that 3/8 pipe thread will work, I plan on using This Femco low profile drain plug.
I like the design v. Fumoto as it's not bulky. I've got them on 2 tractors (11 drain plugs on one), our LX and LC, Honda ATV's, No failures ever. You drain the oil by removing the cap and threading on a brass drain nipple attached to a plastic hose. I shove that into a 2.5 gal. jug and I can do something else while the filter drains...and then finish by draining the pan while I'm doing something else.
No issues whatsoever. No electrolysis as there's no exposure to water. Not sure what you mean by issues with brass.No issues with mixed metals or brass threads?
