JDM battery regulating system (1 Viewer)
Pasadena, CA
Website
forum.ih8mud.com
Max Volt Power System ( Battery regulating system for 80 series Toyota Land Cruiser )
The battery regulating system is designed to stabilize voltage in your Land Cruiser for maximum battery efficiency, allowing its full potential to be released. It provides both function and stylish appearance; units are designed to fit your Toyota Land Cruiser with one additional grounding cable. The most secure and reliable mounting locations to ensure an easy installation and excellent performance. The battery regulating system has three hyper ground wire terminal openings;
1. Simply install the wires from Max Volt Power System to the battery positive + and negative - terminal.
2. Connect the extra Hyper Ground Wire that included with the kit to the other end of the Max Volt Power System, install the other end of the wire to the chassis of your vehicle, engine block, or radiator support.
The Max Volt Power system also feature an LED on the unit also operates as a system monitor, to alert you when your Land Cruiser battery may need service or replacement. In additional, a display of the voltage is also on the MVP unit to show you the voltage of your Land Cruiser battery current.
Toyota Land Cruiser MVP battery regulating system features:
-- Torque up, horsepower up, engine response up
-- Increase fuel efficiency
-- Clean exhaust, low HC, CO
-- Stable and increase power of headlight
-- Reduce load of electronics
-- Reduce noise of audio system
-- Battery life extended
-- Compact Design L: 3 inch, W: 2.5 inch, H: 1.5 inch.
-- Available in Blue or Silver finish.
Now my question is, have any of you ever try to install these before? Notice anything different?
I believe it might reduce audio noise, and I believe it's blue or silver.
The rest sounds a lot like over ambitious marketing.
So LX_TREME- what is this thing exactly? A voltage regulator for your battery? A noise filter? I do not understand what this is. What's in the box? A capacitor? Sounds like hype to me.
It must be good stuff. Just look at the quality & price of their grounding wires::doh:
Toyota Land Cruiser performance parts from MVP ItemNumber:31520 - *27989Product Name:Max Volt Power Ground Wire System Up Kit Toyota Land Cruiser All Year ModelDescription:Toyota Land Cruiser All Year Model Max Volt Power System Ground Wires System Up Kit - Two Groudning Wires in BlueFor:Toyota / Land CruiserAvailability:Usually ship out in 24-48hrsRetail Price:$65.95 Our Price:$45.95 *Shipping:$7.95*Standard service for - Max Volt Power Ground Wire System Up Kit Toyota Land Cruiser All Year Model - shipped within the continental U.S. Additional shipping options available at checkout.Note:Blue Max Volt Power Wire System Up Kit / Two MVP system ground wires includes 15.75 inches and 39.37 inches
Due to make and model of vehicle are differ; installation mounting point of wires and system may vary by model.
several paragraphs that tell you abolutely nothing about what it is, just vauge marketing claims, looks like a BS product.
what you dont like the thin carp $.05 terminals? OK put a few thousands of gold plate bling on them, now you like em right? specifics about wire gauge and current carrying ability? that is for geeks, you dont need that.
:rolleyes:
