- Thread starter
- #101
So a while ago my ABS light came on and the code says it was the ABS pump motor. This is after the lift and the P315 tires so I decide to do the ABS & LSPV delete (the LSPV was leaking anyway). I did a few leak checks and all was good. Even after bleeding, the pedal was still on the soft side. I could lock up the tires on dry pavement, so I decided it was good enough. I did this in preparation for an upcoming Colorado trip, where I knew good braking would be a necessity. The trip went fine (posts below) but the pedal still was soft and seemed softer upon my return. I'll bleed the brakes again this weekend and maybe the master cylinder, and I'll see what happens. I'm a little concerned its the master cylinder or booster.
