J-Robs truck saga
JRob getting it done. Shortening tranny output shaft.
Smoothing out the edges. Cutting wheel on a 4.5 inch grinder worked best for shortening tranny Output shaft. It laughed at the portaband.
Blue tape is to keep metal shrapnel out of bearings.
Finished product. That spacer needs to be removed. We found out the hard way , doh!
DNP=the best shop light (read mag light) holder ever!!!! I always have to balance mine myself......DNP you want a night job?
Get it Jrob.....GET IT!
Great to work on the ole bull.....
Awesome time wrenching and seeing everyone. Next time will be longer.
JRob that truck is going to be badass. El Toro 2.0....
Thanks for the hospitality.
That's how Jrob rolls.....
This is the way the tranny output shaft is supposed to look with the correct collar/spacer installed .
This is the split case and crawl box test fitted. JRob and I put this together after you guys went home to spoon. ; )
Thanks for all the help in this production!
Lighting - DNP
Editors - Lenny/Jrob/Lash/Bodean
Assitant Director - Bomar
Director - Daryl
Digital Imaging Technician - Lenny/Greg
References - Bomar/Georg/ Rocky
Moral Support/Comedy Relief - Jess/Spivey
I ordered the seals & gaskets and the twin stick setup today. When it comes in we can get back to it.
Lighting - DNP
Director - Daryl
I'm not coming over there till this projest is finished or I need a beer, or a cabinet made or get your help on Deb's truck...:D
How did the split case dry fit go? Three thick and two thin spacers?
I think we are at 2 thick and 2 thin. We may go back and try everything again before we put it together for good. We are going to document everything step by step with pictures. We had to grind the case where it hits the shift rail on the toybox. Had to call rocky to make sure that was correct. The case is VERY thin at that point where I had to grind.
I believe it ended up 3 thick 2 thin. When we tear it back down we will make sure. Putting the split case back together wasn't too bad. If we had the seals and gaskets it would be back in the rig.
Jrob time to update your sig. That new f250 tow rig needs some love :grinpimp:
A big thanks to Georg for his help through this process and for getting us to Rocky on Saturday. We all appreciate ya buddy!
anytime. you guys are my peeps! :cheers:
see you at the roundup. i'm counting the weeks! :cool:
X2 on this!! Big thanks to georg and rocky......and you BOSSMAN!!!
I didn't do anything. You and Lenny are the guys here!
x2 !
Don"t be shy now.
Bossman you are more than welcome to start a build thread in the cottonland section for the 80 project.. or any other of your numerous potential projects!
