Issue with spotty shift lock on 2010 Sequoia
Living in the Past
SOLVED
Last few months my Sequoia lock to shift out of park has failed and needed to push the bypass. First it was when parked in a hot garage. Which reminds my of the driver's power door lock on a 2000 100 series and 99 4Runner which happened when it was hot (PHX, AZ). It now happened when cooler. Anyone had this issue and was it the solenoid at the shifter? Only other thing I can think of is switch at the brake pedal?
Transmission range sensor, possibly, P0705 code.
Similar happened to my 07 tundra.
Not even sure what that is. Should the check engine light stay? Only light that stays lit is the tire sensor. Had tires rotated and balanced at a place that supposedly only used nitrogen. When I traveled from 1,000' to 8,000' tire light came on. Pressure on all tires was well over forty pounds. Now need to know how to tell which wheel has the bad sensor. Another problem to figure out is which sensor is bad. I dumped all the air and inflated to the proper pressure then reset the sensors with no luck. Like the shift lock not a huge issue I would just like to get fixed. Drove a lot of years without tire pressure sensors and never destroyed a tire became I ran it flat or too low of pressure.
On the shift lock I'm seeing a Computer sub assy shift lock control. Pricey little piece but if it fixes the problem worth. Does anyone know if the piece mounts directly on the shifter and includes the lock solenoid? Diagram shows it in the correct location.
