So I posted this at the end of another thread that is 9 pages long and didn't get any responses, and I now have more info so I thought I'd ask for help in a separate thread:
So the update: Tonight my wife took the 100 to take my daughter to girl scouts and when they got done the 100 wouldn't start. I drove there and checked the battery terminals to make sure they were on tight. The negative seemed a tight bit loose so I torqued it down a bit. I then tried starting it and nothing at all, other than 1 click.
I could tell from residue in the engine bay that when my wife drove the 100 through the high water that water got everywhere, including ontop of the battery. So I then removed the covers on the battery and looked at the fluid which was full but had a bunch of particles floating around in it. Maybe some of the flood water got into the battery?
I then connected jumper cables to my STI which has very low voltage at idle expecting to have to rev the engine in order to be able to start the 100. However before revving the STI I tried the 100 and it started with zero delay as soon as the key was turned.
After disconnecting the cables, I checked the voltage display in the 100 while it idled and it read 14 volts.
All of this leads me to believe that I have a battery problem and not a starter or alternator problem. However the battery (continental) is only about 5 months old.
I let the car idle for a while when I got home to see if it will charge the battery. Hopefully it will start in the morning. If so, I guess I should buy a new battery? Any suggestions?
Thanks for the help!
Tim
We had flooding here last week and My wife was driving the 2003 LC and apparently drove through some quite deep water judging by the debris on the doors (half way up the outside of the doors). I'm surprised that water did not come into the cab (good door seals?).
However, after driving it this weekend, I noticed that when I turn the key to start, there is often a slight delay between turning to start and the engine turning over (1 or 2 sec). This was not present before. Our LC has ~85K miles on it.
The battery is fairly new, and once the engine starts turning it turns with gusto, so I don't think its a battery problem. Do you think that deep water driving may have damaged the contacts on the starter, or have any other ideas on what might be going on?
Thanks!
Tim
Tim
