I am having trouble shifting. It won't go in to gear very easy at all, it will not go into reverse at all when it is running. The other thing about it is how intermitent it is. It only happens every 3 out of times I drive it. I originally thought it was a possible leaky slave of master cylinder. So I ordered a repair kit for both of them and put it in. I have bleed the line many times and am pretty sure that there is no more air in it. I have run a whole bottle of fluid through it, making sure that the resevoir doesn't go below half full, and have not seen any air coming though the tube I attached to the breather. I am stumped. Any thoughts as to whether it is a bad clutch or my transmission? I originally thought a bad clutch would be one that would slip. It doesn't slip when it is in gear and once it is in gear it drives fine. Any thoughts.
