Is this normal for the gauge on a '06 LX going 75 mph? The gauge on my 2000 LX shows plenty high with original sensor. The oil level is good and seems to drive perfectly.
Where is it at idle? 4000 rpm? I'm going on
memory since my '04 is apart right now, but I'm always surprised that it is on the low side. Pops right up when you tap the skinny pedal though.
Before I switched to M1 synthetic mine was dead on at halfway. Now reads lower. About where yours is at, sometimes slightly lower. Assuming it's ok...still runs .
I had the same issue with 5w30 and 5w20 M1 EP synthetic. I switched to my old favorite, 5w40 Rotella T6 synthetic, and the gauge now reads consistently higher. However, the reason for the change was differen(commonizing all engine oil over my fleet). Highway cruise 75mph is just a little bit over half-way on the scale.
With my '06 LX being new to me, I don't know what oil is in it...whether synthetic or which weight. However, it is very clean and up to proper level with no leaks.
Well acutally I do know now... just called dealer and they said they put in a Penzoil 5w30 synthetic blend 4000 miles ago.
Will there be any issues when I change to a regualar 5w30, 5w40, 15w40 or other nonsynthetic?
No there will be zero issues with switching to whatever oil you want to use. I love Rotella 5w-40 T6, it is easy to find, full synthetic, rated for extended drain intervals and has some of the best cleaning properties you can get in a motor oil.
The T6 is cheap too, $20/gal around here.
