have to disagree with you here.
for the average home garage guy, stick welding stainless will be a handful.
a back purge is not required to weld stainless. however you need to pay attention to your heat setting.
I can't help it.. I deleted my previous post but, I must comment on this one.
I have to disagree Brian...
If I'm looking at a GTAW/TIG weld that lost its purge on a SS weld or was welded without a purge... It's a reject, plain and simple, no questions asked. Purge on GTAW/TIG is an essential variable on 100% of any WPS/PQR I have ever reviewed. I’ve never seen a GTAW/TIG procedure that didn't require/call out an argon purge/cover on GTAW/TIG for SS.
Reason for rejection is that the "Sugar" / "Drywashing" effect is simply... S**T...and if a welder thinks it's OK, I'll jerk his certs and kick his A** down the road (It’s a quality and experience issue) and #2 is:
Two things happen when you overheat SS (THIS IS WHAT SUGARING AND DRYWASHING IS/CAUSES) by not using a purge/cover on SS:
1) The carbon combines with the chromium to make carbides.. This basically robs the surface of the chromium that forms the chromium oxide that creates the stainless' quality.
2) The other thing is that the iron, chromium, and everything else gets badly oxidized and forms scale and there will be a loss of corrosion resistance due to the chromium carbide you have created.
You may think that if you watch your heat you can do without a purge/cover (For a newb... IMPOSSIBLE) however, argon is a "Cold Gas" and therefore that is why it is the most common cover/shield/purge gas used and for a very good reason... I don't care if you talk to a metallurgist, welding engineer, CWI, SCWI, etc.. etc... we will all agree on this. Argon shields/protects the weldment and keeps the chromium safe/cool in its composition to maintain its integrity and corrosion resistance. Heat treated SS (which is basically what has been created without the purge/cover) will crack within days once introduced to an adverse ambient condition/sour gas/extreme cold and/or fluctuating pressures... list can go on for sometime...........
You can "back yard' a SS GTAW/TIG weld all day long.. this is true.. But, with the deletion of the purge/cover gas on SS... you are certainly going to have rust issues (due to #1 and #2 above) within a week and over time the weldment will become brittle/crack and lead to failure.
As far as stick welding SS.. I agree with you.... an average guy in the garage will have to spend some serious time practicing with this or it will be an absolute nightmare.
Boilermakers/etc.. use this everyday to weld CS/SS or SS/SS on SCR's, catalyst bays, etc.. You need to burn this hot, fast and pay attention to create a good quality weld. I've inspected 1000's of them inside power houses over the years. I've seen all qualities of SS stick welds...... I'll leave SS stick welding at that...
As with any welding... practice makes perfect..period...
J
