I have to say I didn't read every post here but I tend to disagree with a lot of what is being said. I dont think a OEM shock is well suited for your needs. You don't want to lift the truck which I think is a great idea for your use. But you will be carrying heavy loads over longer distance. Also on "smoother" roads like forestry roads you tend to go faster than say crawling over rocks. So higher speed for longer distance with a heavy rig you will benefit from a really good shock. Also probably a better spring rate than stock springs will help also.
I did see some people recommending OME 861/862 and I think that is a great starting point for you.
Stick with OEM bushings. If you need caster adjustment, which you should not need, but if you do then use the plates.
Your real question is about shocks. I would buy the best shock you can. If you are diving through Death Valley in a loded rig 8 hours at a time on wash boards that puts more heat into a shock than rock crawling. Plus to me, those long days on remote "forresty" roads is where the extra stability and control of a good shock really helps to me.
I had new oem shocks. They are a bargain and are cheap. For the price I think they are great. But I just don't think they can control a heavy built truck on dirt roads the way a 2.5 remote res shock can.
So I recommend a good stock height spring. Then get the best shock that YOUR budget allows. Icons are not overkill for your need. If you can afford 2.5 remote res shock then I think they would be a good choice.
I had new OEM shocks. Felt ok but they were harsh to me and also kind of soft at the same time.
I had Fox 2.0. I actually liked the way the felt. But they failed at around 40,000 if I remember right. They are rebuildable but need to be sent in to the factory which adds down time and shipping cost. Ends up costing almost as much as new ones.
I replaced those with Radflo 2.5 remotes. They are rebuildable by me. Plus the extra volume in every thing should keep the oil temps much lower and extend the life considerably. Around town I would say they feel maybe a little better than the fox when the fox were new. The fox were nice when new. But on a open dirt road like a ranch road the Radflo are pretty awsome. They just feel better the faster you go. It get to where you realize you are just going way to fast to stop or turn but the truck still feels planted. I have had several dirt ranch road where I get up well over 60 and have to just remind myself to slow down.
Washbards are better but hell I think they suck with any shock. I am happy with myRadflo shocks. I would imagine Kings are even better. Icon 2.5 remotes might be better as well but they do both cost more and had longer wait times which mattered to me when I bought them.
Hope this helps
Hope this helps
