Installing airbags on lifted LC
FL
So my LC is lifted by 2" and recently i have had a need to install an airbags. I plan on transporting the LC and another vehicle cross country.
I see everyone recommending Firestone blue airbags, however, i can't find these airbags installed on a lifted vehicles. Will Firestone airbags work or do I need a separate set up to compensate the 2" lift?
I know that full airbag system acts by making contact between the axle and the frame rail. Since Firestone airbags are "coil helpers" do they also make contact or do the help out by just being inflated in the coil itself which causes the coil to be stiffer for heavier loads. Meaning that the airbag doesn't have any contact with the axle and the frame, which means that the lift is irrelevant and that i can use Firestone airbags
(Edit - wrong - Firestone has a longer version for lifted 200s.) They make contact on the axle at the bottom and the (cut down) bump stop that is inside the spring on the top. Airbagman out of AU has a version with a Kevlar sleeve that might be better protected. When I bought them (and sold before installing) the Firestones were like $120.
Firestone has a longer version for lifted 200s. They make contact on the axle at the bottom and the (cut down) bump stop that is inside the spring on the top. Airbagman out of AU has a version with a Kevlar sleeve that might be better protected. When I bought them (and sold before installing) the Firestones were like $120.
Do you know which set that is? Looking through on amazon i found these with a review stating that they are for standard and raised LCs.
Firestone 4164 Coil-Rite Air Helper Spring Kit https://a.co/d/cWc8puQ
I'd order airbagman but due to a quick move, I'm trying to get a set delivered ASAP.
Looks like i found the right set.
These are the ones I ordered: https://a.co/d/0Nw2AOe
Maybe it was the Airbabman that had a different part for raised vehicles.
CR5151HP Air Suspension Helper Kit - Coil
$448 AUD/$150 of that shipping
Also, Exit Offroad (member @crikeymike ) sells the Firestones.
His page states:
  • Works with 0-2.5″ of lift
Yes, Firestone 4164 is the correct one for a 2" lift. Here's the post from when I installed mine:
I don't remember seeing a thorough install thread for airbags on here, so I'm making this description very detailed.
I added Firestone 4164 helper airbags (and added 1/4" wire loom to protect the air tubes). These are rated for up to 35 psi. You can get the same ones, but with sleeves that bring them up to over 60psi max if you purchase the HD version from Airbagman (but it's like 3x more expensive shipped from AUS). They do seem to be the correct item to go with my 2" lift (this was the advice from a few other comments throughout the forum). Whenever we would go on family trips the past couple years, the gear would make the back sag 1" - 2", so this is to alleviate that problem and make it handle better but otherwise keep my non-harsh ride when the LC is not loaded up.
First, here's a really brief summary of the steps, before I get into more detail:
Prep work:
  1. Jack up rear frame on both sides and place jack stands.
  2. Remove both rear tires AND spare tire (creates a ton more room, I waited too long to do this).
  3. Loosen KDSS bolts 2.5 turns.
  4. Remove top breather bolt (12mm) to avoid damage when axle droops (I prefer removing the top bolt instead of the bottom clamp, since clamps often aren't airtight anymore after removing them).
  5. Remove the first 2 bolts (12mm) holding the brake line (passenger side) where it arrives at the axle.
  6. Remove the bolt (12mm) holding the emergency brake line to the axle.
Spring removal work (an extra set of jack stands can be useful for all axle work, but not required):
  1. Jack up rear axle by the diff slightly to avoid make sure you're in control of the droop at all time.
  2. Remove bottom shock mount bolts (17mm) and hammer shock off the pin.
  3. Remove driver side sway bar linkage bolt - 19mm.
  4. Remove passenger side sway bar linkage bolt - 14mm (be careful on this one, the washers and bushings like to fall off and roll away).
    • NOTE: This is the important step to make removing the passenger side rear spring really easy, and that usually is not mentioned in instructions anywhere.
  5. Jack up the passenger side of the rear axle, and let the driver side droop.
  6. Push down on the driver side wheel hub with your knee, the axle should droop enough to get the spring out.
  7. Jack up the driver side of the rear axle, and let the passenger side droop.
  8. Push down on the passenger side wheel hub with your knee, the axle should droop enough to get the spring out. You might need to brace your back against the wheel well.
Airbag work (just following the included instructions):
  1. Take the pyramid-looking bump stops out of the springs and cut off the lower 4 sections.
  2. Put the airbags in the springs (hole toward the top).
  3. Cut the provided tube in half, and add the wire loom now if you have some.
    • NOTE: leave at least 1" bare without loom on one side for the next step.
  4. Push to securely connect each section of tube to the easy-connect fittings on the airbags.
  5. Thread the tube through the hole in the shortened bump stops, placing the bump stops where they belong on the springs.
  6. Stand the spring/airbag/tube combination on the ground near where they belong on the axle.
  7. Thread the tube through the top frame hole where the springs will rest, and temporarily bring them out through the gap in above the frame into the wheel well. This will make routing a lot easier.
  8. Install the spring/airbag/tube combinations back onto the axle. Do passenger first, then driver. Same procedure as when you removed them - push on hub with knee and insert springs (make sure to align correctly).
  9. Route and zip-tie along the top or outside edges of the frame (there are lots of other tubes and cables in there that you can bundle them with), until you reach your target where you'd like to install your air valves. You'll have a ton of extra tubing, just leave the extra for now.
    • NOTE: Make sure you consider spare tire clearance.
  10. Install your air valves (1/2" top and bottom).
    • NOTE: A super convenient valve install point is in a little metal tab that is hidden but easily accessible under the plastic flap when you have your tailgate open. The existing holes are just barely too small, and need a tiny bit material drilled out first (and paint to protect from corrosion).
  11. Trim the tubing to the correct length to reach the air valves, but leaving a little slack. Remember to trim the wire loom back at least 1" from the end.
  12. Securely press the tube ends to the easy-connect fittings on the air valves.
Finishing up:
  1. Connect the sway bar linkages in the reverse order that you disconnected them. First the passenger side (jack up driver side axle first, then should be easy to manually place with the washers and bushings).
  2. Leave the passenger side axle high, this will push the driver side sway bar down, making it easier to bolt it back up to the driver side linkage (do this now).
    • NOTE: you'll probably need to use a jack or ratchet strap to push the linkage up the rest of the way to the sway bar. I used a jack.
  3. Replace lower shock mount bolts. Raise or lower each side of axle to make the hole line up, hammer the shock onto the mount, then install bolt.
    • NOTE: Make sure the tops of the springs stay inserted on the mounting lip, as they like to fall out during this.
  4. Reinstall emergency brake line bolt.
  5. Reinstall 2 brake line bolts.
  6. Reinstall breather bolt.
  7. Reinstall wheels & spare.
  8. Lower vehicle, and let it sit on level ground for 10 - 15 minutes (maybe even bounce around a little on the rear, too) so the KDSS system settles.
  9. Tighten KDSS bolts.
  10. Inflate airbags to 5psi (minimum when not using them.
    • NOTE: I added a hand pump to my gear that goes up to 30psi, since the airbags max out at 35psi. The hand pump works pretty good, and I will use it only when I need to make small increments (15 pumps for 5psi) or don't want to get out my bigger compressor.
Lots of pictures coming next...
I wish they'd sell the kevlar covers here for the Firestone bags.
I bought the Airbagman version online in Australia delivered in about 3 weeks and run them at 30psi when towing our 7000lbs travel trailer. I purchased the regular non lift version, they have for a lifted 200 as well.
The 30psi pressure (high end for firestone bags only) puts our combination real level and I have had no occasion where steering was feeling ineffective/light (LC200 is in generally heavy and together with engine has plenty weight on the front axle) or experienced any sway from wind or 18 wheelers or pick up trucks passing at high speed (an additional feature of most WDH).
It does make hook up real simple and maneuvering at the house, campsite or fuel stations. Also keeps the distance of the tow point to the rear axle a couple inch shorter further reducing issues with sway in the first place. I know my approach is unconventional here in the US, however the LC200 is a champ and feels confident all the way up to 75 to 80 miles an hour (be it I mostly tow at 70 to keep fuel consumption within reason).
In short pleased with Airbagman at 30 psi and no WDH. Also thought I buy the "best" airbags when I am going to invest the time to self-install. Tend to do the same with OEM parts when I wrench myself.
Also rented once an HQ19 in Albuquerque and took it to Colorado and Utah. Same experience, just airbags at 30psi and the LC200 is fine.
Reminds me, Utah is awesome!
Thank you all for the info. I have the airbags on order. Will report back the cross country car transport.
Raised version
And a nice install video of the same. I recall making sure the front wheels were really well cogged (with wood against the garage concrete slab and an edge preventing any movement forward) as you lift the rear so no parking break or transmission Park effect any longer. Also used bigger higher rated jackstands at the back of the frame and additional pair more forward. Then tires under the frame as well. Cannot stress how careful you need to be spending a long time under there and doing some serious wrenching at high torques.
In addition, disconnecting the KDSS despite the 2 turns, stroked out the KDSS piston, so I had to use my hydraulic jack to push it back in place and reconnect. After all it worked out great and really pleased I have this ability.
Raised version
Unfortunately I will have to have a shop do this. I moved to WA without bringing any of the large tools to do this, and the driveway is not flat.
