Yes you have heard a tube amp clip, that is what you are calling bloom. Unless ou are pushing 500+ watts per side, you have had an amp clip on you, whether you realize it or not. The difference is that when a tube amp clips, it rounds the waveform and produced mostly even order harmonics, which is what gives that bloom sound. They start to run into what is termed "dynamic compression". When most solid state amps clip, they tend to have a sharper cutoff of the waveform, but also produce primarly odd order harmonics, what you term that horible hideous distortion. How an amp clips however is much more than solid state vs. tubes. It is a function of power supply, regulation, circuit design and output devices. For example, a FET will sound much more like a tube when it clips than bi-polar output device because a FET is a current limited device like a tube instead of a voltage limited device like a Bi-polar device (I may have the voltage / current limited flipped).
You also need to seperate out distortion from clipping. Distortion is any change in the signal from the original. Clipping is a form of distortion.
FYI, I have heard more tube amps than most people will ever in their life. Everything from 3 watt SET amps to the large ARC 1kw monoblocks. Out of the group I still love triode's. I have yet to find a tube amp that works for me for two reasons. 1) I am unwilling to spend my time tube rolling, baising, waiting for the things to warm up, etc.. If I am going to have tubes in my system it will be in the pre-amp. 2) I simply am unwilling to spend the fortune that is necessary to get enough tube power to drive my speakers. My Maggies really need about 500 watts per side into 4 ohms to sound right, and really like 1kw per side. This is the reason that Jim Whiney has always paired them with either big Brystons (like the 7B monoblock) or the huge ARC amps when using Tubes. (that and ARC was the original Magnepan distributor).
Cary
Sheesh Cary, control the caffeine bud
, we are gonna get nowhere here cause your definition of "clipping" and mine are mostly different. Remember when I wrote "us tube freaks" well, apparently our language is as incompatible as our equipment. When
I'm saying "clip" I'm talking the absolutely audible "clip" that happens to the solid state setups as they are overdriven. I accept and acknowledge that when
you say "clip" you are referring to the the overdriven state of almost any amp (I'd love to see the ARC's "clip" as you are defining it
) and what happens when the waveform's signal will abruptly stop towards the top end. So we are both right by our own definitions. How's that for a cop-out!
What I'm saying is simply with solid state stuff (Not all of it of course, but for the purposes of my tube fanaticism I'm gonna go generic there! Ohh, none of my slanderous statements about solid state applies to Krell and some select others
) the distortion that is experienced is extremely "unharmonic" if thats the term and at some set point the speakers clip loudly and then the damage and destruction starts. You do not normally get that with tubes. As a funny: I attend audiofests all the time and we tubists typically go to the solid state setups to make them audibly distort and then go to the terrific tube setups and listen to them audibly bloom. We all absolutely realize that with tubes it is indeed "distortion" in that the original signal wave is altered but you dont giva damn when it sounds so sweet. Its sorta like the difference between the buzz you get from good Rum, and the buzz you get from a square punch to the pucker-upper - both are deviations from regular reality, but one of em feels better
! Anyways, I definitely did not mean to make the argument insulting to anyone at all who is proud of solid state stuff, like I've written over and over tubists are fanatics!
Ohh, all that stuff you wrote about tube equipment, I dont have to bias anything at all, I dont have to roll anything at all, I dont have to wait long warmups , nothing much more than testing the tubes every five thousand hours or so or whenever they sound sorta strange and while my macs cannot properly power your Maggies, they definitely do well with my B&W's and those aren't the most efficient examples of speakers either. Anyway, all I'm saying is I'm a fanatic, and I invite you or anyone at all to join the cult!
No offense meant to you or to anyone at all. Laters.
