You have to use the RCA's if you use the factory amps or any other amps. If you use the speaker outs on the harness, then you would need to run speaker wires. There are some harnesses available with no RCA's. It all depends on the application.You dont have to use the rca can just use speaker outputs from radio into the aftermarket harness its call high level input it will work fine.
