I replaced the worn out steering rack with a new Toyota one, I also replaced the CV axles with some low mileage used ones cause drivers side boot was torn, tie-rod ends and sway bar bushings.
When I was replacing the rack I tried to make sure steering wheel was straight when removing the old one and installing the new one. Now that everything is tightened, the passenger-side toe angle faces in quite a bit, I threaded the tie-rod ends the same amount of turns as the old one and rack seemed straight when it was first put in. Is there a way to correct this Pryor to installing wheels/tires? Did I screw it up?
