The mounts themselves if they've never been doneIs there anything with the motor mounts worth replacing while doing this job?
Only if they are damaged would i replace them.Is there anything with the motor mounts worth replacing while doing this job?
Awesome... I updated the file with yours.I've updated the step-by-step .pdf doc with items such as fan shroud & clock spring warnings, and updated torque values.
@tracknod, could you maybe remove the .pdf from post #273, or replace it with this latest version? Thanks!
Yea, just back off the TRE lock nuts and turn the threaded rack shafts (actually the “inner TREs”) to unthread the outer TREs. Your wheels will splay outward in the process. Be sure to document the TRE positions on the shafts before you start to get your alignment mostly correct when you reassemble things.I had a shop replace the tie rod ends within the last year or two. Is it possible to replace the rack without separating ball joint from knuckle?
I tackled this yesterday. I had to loosen the two steering column bolts near the firewall to get the coupling undone at the rack. Now I can’t remember if that washer it the top of the column was flush with the firewall or not. I can an inch or so of splines and washer is not flush.
About an inch of spline showing.That's the same as mine and it hasn't been loosened.
What’s the part number for this gasket? I’m going to attempt this job on the weekendAWESOME!!!
I hate that you lifted the engine...because i have an engine hoist in my garage i could have easily done that as well.
ALSO!!! That little gasket that seals the adapter to the block to keep in oil failed this weekend!!! Not spectacular failure but enough escaped over 450 mile road trip and 2 days of hard wheeling to make things wet in there.
So i will be ordering this new gasket and replacing it this weekend. I think it can be done without too much hassle. and im going to use a little bit of silicone this time as well.
Ah, thanks. I'll do that.You can rent one.
