Installation of left rear window regulator and window lift motor FZJ80
Just finished the installation of a new window lift motor and regulator, left rear door, FZJ80. The entire process has been posted up in the past so just hitting a few high points FWIW
It's not super difficult and there's a lot of words that most people may not want to read (you might once you dig into this job ;) ). Just sharing a few tips I ran across while doing this job. I'll add some photos.
Removal of the door panel is fairly straightforward, key point is to ensure all the plastic rivets are removed. Don't tug gorilla style on the door card to remove it, otherwise you may cause damage to the door panel which is (now) 25 year old, often water damaged, Masonite (pressed wood and glue) along with plastic parts attached. Use a proper auto upholstery tool to pop the rivets out and take your time, IMHO.
To replace the regulator or window lift motor IMHO they both should be removed together, some people apparently have just replaced the motor in place but in that situation you aren't able to fully inspect/clean/lube the regulator. FWIW
Best to have the window glass in the full up position before you start if possible.
Use a good tape to hold the glass up before you remove the regulator, run a few strips up over and down both sides of the glass. I used Gorilla clear tape and left it on awhile (days) in the hot sun so getting the adhesive off the glass was a real pain. I just didn't want to drop the glass, but maybe
painter's tape would have worked just as well (as long as it doesn't rain, but it did).
There are four short 10mm bolts (90080-11224) that need to be removed after disconnecting the power harness to the motor. The vapor barrier does not have to come completely off to remove those bolts, I cut a small slit in the plastic above each bolt and removed the bolts through that hole. When you put it back together you can patch those small holes with clear vinyl tape. The rear section of the vapor barrier does need to be peeled open to get access to the regulator and motor. Extra Butyl rubber rope can be used to stick the vapor barrier back on, or if there's still enough original butyl rubber remaining something like Gorilla clear vinyl tape can be used to go around the edges.
Once the four bolts are removed the regulator and motor slide out the large access hole.
A new OEM regulator comes with some grease on the regulator plate and the plastic wheel, I added more. The FSM says to use MP grease. I used some OEM body grease (the expensive stuff) along with a touch of a Moly based grease for the motor pinion gear and regulator teeth. Toyota does not use Moly (black) grease IMO possibly because it will make a holy mess if you get it on any interior parts and will never come out of fabrics, carpet, etc, so be careful if you do use a Moly MP grease. I used the OEM Body grease (yellow stuff) for the plastic wheel and lift channel.
If you are installing a new window lift motor you can reuse the original hex lobular screws (90080-14057) which are self tapping if there's already a hole (there is). However I went ahead and tapped the holes (5mm x 0.8mm) at least part way down then (I used) a Low Strength Purple thread locker (personal preference, not required).
One point: when I installed the motor onto the regulator I positioned the motor and regulator so there was maybe one centimeter of movement on the regulator plate remaining from the very end ie: moving in the UP position. Reason for this is the motor will stop, AFAIK, when it either runs out of teeth (movement) of the regulator plate OR when the glass hits the top of the door/window frame and stops moving in the full up position; either will shut off the motor.
Reason I did this is I didn't want the glass to stop moving before it was fully closed, if that makes sense. If there's a more scientific way to do this IDK.
This is something that's hard to describe, point is, pay attention to the location of the regulator arm when you install the motor. Run the regulator up and down (outside the door) so you can see how it works to raise and lower the glass before you install the motor.
Obviously, there is no regulator spring to worry about for the rear doors.
So before I reinstalled the regulator/motor I first connected the new motor to the power harness, turned the ignition key to ON, then ran the motor through it's full arc a few times (regulator sitting on the rear seat over a clean rag).
Before I installed the regulator/motor assembly I ensured that the glass was still in the full up position (it had sagged since it was first taped up).
Once the assembly was inside the door cavity I slid the plastic wheel into the lift channel (it can hang there a minute IMO if you're gentle and have to reach for a bolt/tool). Then started to install the bolts loosely, front right bolt first then wiggle wiggle wiggle the regulator to line up the other bolt holes and install the remaining bolts loosely one at a time (see photos).
Photo below shows the first bolt (front right) partially hidden by the vapor barrier (click twice and look closely). This first bolt was loosely installed which allowed the regulator to pivot while lining up the other bolt holes:
Before fully tightening down the four 10mm bolts I ran the glass up and down a few times to let things settle, then final torquing of the bolts and then final recheck of the glass movement full up and full down. I decided to use new bolts (90080-11224) as the original (attached) lock washers might be a bit weak after 25 years.
In the photo below note the position of the regulator arm wheel in the lift channel, the photo was taken when the wheel was at it's maximum rearward position in the channel (window glass about half way down).
NOTE: The glass and lift channel were however fully up (out of sight) when the regulator wheel was slid into the channel. This is done by feel mostly. The photo below was taken after the bolts holding the regulator to the door had been installed and tightened down
If you find that wheel is coming out the rear (open end) of the channel or right at the very edge of the channel at any point in it's travel arc, then IMHO either the channel has slipped forward on the glass or it was not installed in the correct location on the glass ie: you shouldn't have to pinch the end of the channel because the wheel should not get close enough to roll out. If the wheel does come out of the track something is bent, broken, loose, or misaligned.
This shows attachment of a new window lift motor to a new OEM left rear window regulator.
Note that in order to attach the last hex screw (T-25 Torx/star bit) the arm of the regulator must be repositioned by hooking the motor up to the power harness then with the ignition key turned to ON and using the door window switch to move the arm out of the way to install the last screw. The hole in the arm does not line up with any of the screws.
I used Low Strength Purple thread locker on these screws; not required but
FWIW it's the correct thread locker for small fasteners going into aluminum (if you use anything). I use it mostly as a thread sealer to prevent corrosion
in the threads over the next 25 years before it has to come out again.
The next photo is looking down from above at the partially open left rear door and rear seat. The motor has been hooked back up to the power harness to move the regulator arm.
Installed a new rubber glass run in this rear door with the glass in place.
Short version:
The rubber can be pushed down the channels with the glass in place, lube the rubber with something slick (not thick), and don't leave the rubber out in the sun before you start.
Long version:
After removing the old rubber I cleaned the channel, not very dirty in my situation. First coated the channel with 3M Cavity wax idea being to decrease the chance for future rust under the rubber (read on).
Dropped the glass to a few inches above full closed, started the rubber down the channels on both sides (longer leg of the rubber goes to the rear). Lubed the rubber (front and back 360') and the channel itself with UV Guard Vinyl/rubber protectant (because I had it laying around) but I'm sure anything slick will work. It did take time, pushing an inch at a time. It became obvious that the 3M Cavity Wax I had applied earlier to the channels (to decrease future rust) likely made it more difficult than it would have been otherwise but then the UV Guard protectant sprayed into the channels helped reverse that.
Once I got the rubber in as far as it would go (about 2/3 down) on the rear channel I then raised the glass all the way up, then reached in (door panel removed) and grabbed the end of the rubber on the rear side and pulled it down. Didn't have to pull the front side down from below, it went all the way down with some persistence and persuasion.
One thing that made it a bit more difficult was that I had left the rubber outside in the sun (95"F) for maybe an hour (while I was inside cooling off) after coating it with the UV protectant and the rubber got very soft. I'm sure it would have gone down the channels easier/quicker if I had left the rubber glass run in the air conditioned house then taking it outside to install.
Note the orientation of the rubber "lips" of the glass run, the fatter side goes on the inside of the glass/vehicle (sorry, photo is slightly out of focus):
This photo gives an idea of how floppy the rubber got from the heat:
Last photo shows the rear leg of the rubber pulled down the channel, I then pushed it back up a bit. The door panel/card does not have to be removed if the rubber slides down the channel. I had just installed the regulator and motor so it was already open:
Note in the photo above the tan/yellowish streaks on the interior of the door cavity; that's 3M Cavity wax I sprayed on after cleaning, priming, painting, adding lumps of Butyl rubber over the original foam adhesive between the crash bar and outer door skin, and adding sound dampening material. FWIW
Very helpful, thank you! I replaced the motor in my DS Rear window and your contribution was great help. Other than discovering the Dorman motor I received from RockAuto was for the wrong side (up goes down and down goes up) I’ll call it a success for now. Thought I’d get cute and use Shin Etsu and silicon lube for the window runner, but ended up going to the old soap and water method. I had to pull the rear side down from the inside of the door as well. Replaced the outer door molding as well, and discovered that I should have ordered the bottom rubber piece in the channel where the window rests as I have some play there. Oh boy I get to do it again!
"up goes down and down goes up"
I had the same result the first time I installed an aftermarket Dorman motor in the driver's door. IME the issue wasn't the wrong motor,
it was due to the wiring going into the motor was reversed. To correct it I disconnected the wires from the motor side connector, swapped wire positions (inside the connector) put it all back together and voila, all good again.
@77mustard40 did you remove the regulator to swap your motor? Or did you just reach in and unscrew the motor? Beautiful 40 btw. Thanks!
I followed @Kernal and removed the regulator, swapped the motor out and re-installed it.
He mentions starting this job with the window all the way up - are you able to access the two bolts that hold the glass to the regulator in that position? Or do you have to have the window down, unbolt the glass, and then pull it up by hand and tape it in place? Thanks for your help!
I taped the window in the up position so it won't fall and then unbolted the regulator, there is a slot in the channel on the bottom of the glass that the regulator roller slides in and out of. If you are also replacing the glass retainer at the bottom of the window (sorry don't know what that part is called) then you may have to drop the glass to get to that.
The rubber piece that fits between the glass and the channel that holds onto the glass so it can be mounted to the regulator is called a Filler. FWIW.
Removal of the door panel is fairly straighforward, key point is to ensure all the plastic rivets are removed. Don't tug gorrila style on the door card to remove it, otherwise you may cause damage to the door panel which is (now) 25 year old, often water damaged, masonite (pressed wood and glue) along with plastic parts attached. Use a proper auto upholstery tool to pop the rivets out and take your time, IMHO.
If you find that wheel is coming out the rear of the channel or right at the very edge of the channel at any point in it's travel arc, then IMHO either the channel has slipped forward on the glass or it was not installed in the correct location on the glass ie: you shouldn't have to pinch the end of the channel because the wheel should not get close enough to roll out. If the wheel does come out of the track something is bent, broken, loose, or misaligned.
@Kernal thank you for the in-depth write up here. I am about to tackle this 4x. Quick question; at what point in the process did you unbolt the glass from the regulator? Are you able to access the bolts that hold the actual glass to the regulator when the window is in the full up position? Or do you have to unbolt the glass when the window is down, and then raise the window to tape it into position? Thank you!
@77mustard40 thanks for the reply. My question is when did you actually unbolt the glass from the regulator arm? Are you able to access the bolts that hold the piece of glass to the regulator arm when the window is taped all the way up? Or can you only access those glass attachment bolts when the window is down, before you raise it up into position? Thanks!
I never removed bolts that hold the glass. The regulator arm has a roller at the end and it fits into a channel that has a slot that lets you remove the whole regulator without dealing with channel that hold the bottom of the glass. As @Kernal said above, if you are also replacing the “filler” you will probably need to lower the glass after the regulator is out of the way to get to that. Dive in, it’s not that hard to figure out once you get started.
Been awhile so I forget the actual height of the glass where I unbolted the regulator from the glass support channel but it will become obvious once you get to that point. You'll have to adjust the position of the glass (using the door switch) until the two 10mm bolts are accessible with a socket tool via one of the openings then tape the glass up and over the top of the door so it doesn't fall once you disconnect it from the regulator (or, just pull the glass up and out of the door). I have more photos showing the process somewhere and will post them up if I can find them, but again it becomes obvious once it's all in front of you. HTHs
Gotcha - well thanks for the reply, I appreciate it.
@Kernal thanks a lot for the reply - have a good one!
Must be different from the front window because that slot has a lock on both ends preventing the regulator from being removed from the window channel. Edit: Just confirmed that it is indeed different from the fronts. :)
