Inspection Cameras, Which One should I Buy?
So. Austin, tx
one big issue would be the size of the smallest hole you need to look into. When I was looking at cameras like that a while back, it was noticeable that the wand ends were not that small and many of the inexpensive ones may not have fitted in a spark plug hole for instance. For really small holes, the prices jumped up quite a bit.
You need to decide:
1) diameter of camera/illuminator head (you want to be able to adjust the light intensity).
2) resolution you need
3) live view only or capability to store an image for retrieval onto a PC
there's other stuff too - but that's your basic list to whittle down the options.
I scored a free extech br80 (VERY basic unit) which was a 'gift' that I chose when I bought a Flir thermal imaging camera. The br80 is 'ok' (for free) and I've actually used it a few times to get an idea of what something looks like without having to try some contortionist sequences to see directly. I have no need to take a snapshot, so a live view is fine.
Anyhow, figure out 1), 2) and 3) above first.
cheers,
george.
Thanks All for the replies... Camera would be mainly used in the commercial/residential ac business, mainly to look at evaporator coils etc.
Harbor Freight has one just to view for $100, and one to store pictures for $200.
They always have coupons running 20% or 25% off one item is common.
http://www.harborfreight.com/catalogsearch/result?q=inspection
I'm happy with mine - I got the one that stores pictures. Small end at 8.4mm, 640 X 480 pixels, rechargable battery. Used it first to inspect my FJ40 pistons and cylinders through the spark plug holes.
nice to be able to look inside a cylinder, but man, I'd be on pins and needles using a mirror on the probe inside the cylinder if it's not extremely securely glued on...
