TBs had never been touched on this LX, started with 7 turns and got a few readouts at the front averaging 7.4. Gave it three more turns to try to get down to spec range, & then it got wierd: 6.9, 6.3....then 3.0. Since then, I have been unable to get a consistent (more than two in row within 0.4) pattern. I backed off 1-1/2 turns and got a few 6.7s, followed by a 7.1. Loosen 1-1/2 turns and 8.2, 8.2, 3.0. Currently hovering around 6.5s to 6.9 and maybe I'll just call it good, wearing out my AHC, ha.
Is this an indicator of a problem - is it normal or should I be getting a tighter pattern?
(Accumulator has been steady at 10.5 to 10.4. Rears are consistently 8.5 - 9.7 range depending on what I'm doing at the TBs, plan on replacing springs to try to tackle those #'s.)
After doing any TB turns I do a short drive, maybe just to shake out anything from the adjustment. Have always noticed a bit of a shudder/thump at the front end when shifting N to Low and back to N, as if sticky. I'm just driving a few yards back and forth to activate AHC.
Fluid is at spec, was bled/changed about 20K ago.
Can't end w/out thanking the Mudders here & solid threads here that helped me to get the Techstream running ("Techstream in 5 minutes" did it).
