In 24 hrs...
Unoman
Austin
Friday 8pm to Saurday 8pm. I might just get this done by roundup :grinpimp:
Thanks, hope to have it running today
Wow! Here I thought I got a lot done yesterday.
Don't be so modest. What you did yesterday pales in comparison to your stupendous accomplishments this afternoon. :cheers:
Lookin' good, sorry I missed your call Sunday, my phone didn't ring (I've about had it with it, need a new one!!) and I didn't know you left a message intil about 5:00 yesterday...Like you, I'm still thrashing on mine, and probably will even at K2
No worries WL.
Actually got to take it for a test drive last night around the hood. Was running great and then just died on me. Dist cap looks toasted. Got a new one in hand with new plugs, wires and rotor.....that should hopefully cure the issue
Ok, well the new cap, rotor, plugs and wires didn't fix the issue. I have spark and fuel at the rail. It was running great last night and then slowly lost power and the motor completely shut off. All electrics were still working...lights, radio etc. Engine will turnover, but won't fire. Any ideas? Btw, I have a 3fe
What should I look for with the fusible links? I popped in a brand new efi relay and that didn't help.
The ecu is grounded to the tub. The starter has a ground to the frame and the neg batt cable is also grounded to the frame. I'm running the same fuel pump as before. When I turn the key to "on", the main relay clicks. I can push the trap door in the afm and the fuel pump kicks on. It's almost as if the injectors are not functioning.
Mark....did you have an efi relay? All I have is the circuit opening relay and the main relay. Two fusible links. I was running it this was for an entire year without issue
If you're running the stock fusible link harness, then you can check continuity.
Can you swap FPR on the fuel rail. I used a aftermarket FPR, and capped the end of my Fuel rail, and off the FPR was a return line to the tank.
I'm running a msd2225 fuel pump with the stock 40 tank. I haven't checked what the actual pressure is yet on the rail. A possible FPR swap is not out of the question. While the short block was being rebuilt, I changed out the fuel filter for a new one. I definitely know its getting fuel as the brand new plugs smelled like gas and had some residual fuel still on them from trying to start it so much. I've tried two different dizzys and each is providing spark.
Did a compression test to see if the headgasket was still in tact and found I'm at 120-125. Head was dropped off to be rebuilt, should be done tomorrow. So, we'll what happens once I get it all back together.
The mind boggling part of all of this is that the truck was running great before doing all of this. The only reason I had the short block rebuilt was due to a knocking wrist pin. I drove it that way for a year without issue. One would think this should be a plug and play operation.....but it's never that easy.
Tucker...how is your FPR hooked up? Can you take a pic of the VSV and FPR?
