Ignitor Schematic
I cranked over the motor. Ohms jumped around a good bit, but no continuity reading.
That jumping around indicates its working........
Some meters react different than others........
I basically just use the [audio alert] function on my cheap-ass Fluke, it'll sound off with a (beep) every time the rotor protrusion passes the magnet, even at cranking speeds.......
Soooo.......post up a few pics that you were threatening us with earlier.........
you seem to have 2 ballast resistors and you only need one. The one on top of the ignitor is the stock one.
That is a 1975 USA ignitor. It has a ballast resitor for the coil, and a ballast resistor for the ignitor. Later points ignitors did away w/ the ignitor ballast, and just ran the ignitor off straight 12V.
I think you don't need ( the one on the fender), I can't see any reason for it.
The the resister on top of the coil you need (it will help the coil).
Just one question the 2 wires going from the igniter to the + and - of the coil were they ever disconnected or their original connection is still as is??
Original still as is. I found an old picture, and the po DID have a tachometer mounted on the steering column, which would explain the resistor mounted on the fender thus the cut red wire would go there, which makes good sense.
You have a semi-electronic so only one wire from the points to the igniter.
So as far as power hook up , I would say just follow Pin-head's advice.
But you can always check to make sure.
1- BLK/yel ( the one from the starter selonoid ) goes to + termina of the coil.
2- blk/yel (from the ignition switch) goes to ballast resistor (the post with the nut)
The other resistor that mounted on the side of the coil. I am not famliar with. I would say you don't need it?
To complete the wiring one wire from igniter to - terminal of the coil and one wire from the from igniter to the points via the lyyle bolt on the side of the dsitributor.
There might be a grounding wire for the igniter. which you can checked (continuety between the wire and igniter body) means it is just a grounding wire.
The wire from igniter to - terminal of the coil will possibly have a round connector in the end of it. While the one from igniter to the points will possibly have a plug in the middle of it ???.
The wire on the - side of the coil (that has the grren plug) is not needed unless you have a tachometer. I believe that is where it is going, because I can see it spliced to a green wire in the pic.
So you should post pics that will show the connection to that (unkown resistor) and what I belive is a little condeser under the assembly.
And you can measure the resistance across those 2 resistors and post them .
Here is the proper hook up and a pic of the dizzy.
Thanks again.
FWIW, that is not a Denso dissy. And it is not vacuum advance.:frown:
I know. It is a mallory. And thanks for the vacuum advance. My mechanic buddy is in a tizzy saying we are going to have to run a line...
If the distributor wire is the same red wire that goes to the coil, then the ignitor is bypassed and is not working. It is just a regular points type ignition with the ignitor just for show.
That is great info. And it is the same color.
Thanks again.
Truck runs great at about 17ish " of vacuum. Wondering if the configuration I have would need the computer, and the vsv box with the 2 green plugs(emissions stuff).
the po had the cannister, and the box, and the computer all hooked up. Seems to be fine w/o the aforementioned components.
Start a new thread w/ pics of the current vac hose, canister routing.
To all that helped me: I found my problem. There are some dumb people in this world, but I rank at the top. Worked for 3 weeks trying to get her to run and nothing. Finally, I waited a day or so and said that I would go out and look her over one more time. In looking, I found that I had the plug going from the ignitor to the distributor hooked up wrong. Switched it around and she purrs like a kitten. Now I am ready to move on to another project on my cruiser. Thanks to all. IH8Mud is great.
