I am at my wits end on the ignition problem with my 78 FJ40 with 2F engine. It has the OME electronic ignition system on it. Was running fine, but I had a rear main seal leak. Pulled tranny and transfer case and replaced seal. After putting back together, started her up and it ran fine for a few minutes. Then, sometimes it would run for 5 minutes and next time only 1 minute. Now, she will not crank at all. I don't see how the tranny and transfer case removal could have anything to do with this, I think the ignition problem is a separate problem. With the ignition switch on, I have power to the two prong plug that feeds the ignitor. But it seems as though I have nothing after that, but I really don't know how to check on down the line to see if the ignitor, coil, or distributor are the cause of my problem. Thought about getting an ignitor, coil and distributor from cruiserparts.net and just replace all of these, but I hate to spend $250 if I can narrow the problem down. Can anyone out there in cruiser land offer me any help or advice? I have always prided myself on being a fairly good mechanic, but this one has me by the balls, and I need them for more fun things. Help me please if you can...
