If a rear exhaust system was available in production run quantities, say for 98-04, what would be some of the considerations or benefits that you would want, and perhaps, how would they be prioritized?. I've read through several other threads and the obvious targets should be addressed, such as high clearance, not too costly, lifetime materials - SS, ...???
Would you want something that kept the peace and quiet, or quiet until you stepped on the loud pedal to let the world know that V8 is in the house?
Also, since performance gain of 178HP is not realistic, I'll only ask that we get 92HP gain. Bolt-on, mind you. At full gross weight + 4,600 Lbs in back, while towing an 8k Lb load. Going uphill. In the snow. Passing everything but the gas station. And, we should also be reasonably expected (guaranteed) to achieve 17.5 MPG, as well. Almost forgot that part.
Yeah, right.
OK, at least it should uncork the back end to help eeeck out any performance gains if something is installed on the front end (i.e., DT headers), with installation being a
and
job.
If some or most of the input could be engineered into an aftermarket system, is there any interest? (I ask this separately from the above "considerations/input" because some will have great ideas & input, but would not buy).
Yeah, right.
and
job.If some or most of the input could be engineered into an aftermarket system, is there any interest? (I ask this separately from the above "considerations/input" because some will have great ideas & input, but would not buy).
