I know i have heard talk about this, my mind must be going but i head TLCA sold somthing like this, i know SOR does but that is damn pricy. I'm gathering a list for parts for a de-smog. i know i need to pick up some vac line, erg block off plate, and a smog pulley....i know i can gut it, but would rather just have an idler there.
i like cheap and easy, or expensive and easy, but i don't like cheap and hard. how much "work" would it take to put it a $30 saginaw pump? I currently do not have power stearing.
Forget the pulley, and just get a Dayco #22528 belt. That lets you remove the smog pump completely. It bypasses the alternator also, but since the alt is a double pulley, that's not an issue. You'll have to adjust the idler just above the A/C compressor out quite a bit ot tighten the belt, but it's a much better route to go then installing an idler.
Then again, this is assuming you're doing this to a 3FE
Okay, you are going to have to use your imagination here.
This is an image taken straight up into the engine compartment.
The bar on the right is the steering shaft.
The rough surface at the left of the pic is the stock Smog pump bracket.
The smooth surface is some 1/2" (I think) square tubing
I welded a nut on each end of the tubing to act as a bushing for the stock smog bolt to ride in.
What you can't see is a "U" shaped bracket that is welded to the square tubing and actually bolts to the power steering pump.
