Hey all,
The Black Pearl has been running great, other than a loopy idle. It seems to never want to come down to 650, and usually sits like 800 when I'm in gear, about 1050 when in P.
I have been playing with both the IAC and TPS, and just did the o-ring mod on the IAC. Two o-rings made it so it wouldn't start, and one improved it a little bit. Instead of starting at 1800 rpm I now start at 1600 .
Anyways, now I'm playing with the TPS. I would assume that the idle RPM should be changing when I move that sensor through its range. However, it doesn't seem to change the behavior of my truck, even when I have it in the furthest or closest orientations. I kept reading that the idle is completely ECU controlled(1993 1FZFE), and that I may need to like pull the efi or just wait to get it to try and update itself. Curious if anyone has experience playing with the TPS -- I do not have the tools to do the diag using vaccuum and don't think I need it here. Just trying to understand if my TPS is faulty, which I think it may be. Spring in the TPS has good action, and it pulls back to the left strongly when the set screws are loose. For whatever reason, adjusting it is not changing my idle.
So, do I just need to wait longer after making an adjustment to see a result? Make sure I reset the ECU?
THANKS ALL
Chris
THANKS ALL
Chris
