I keep a extra 10 pack of crush rings as well as some of the Microscopic o-Rings on-hand in shop basement parts dept. at all times
Alright, here's where I've landed with this whole saga, after 3 days of testing every got dang vacuum system component on that effer.
I've managed to get the truck at least idling pretty smoothly and getting about half the power out of the torque.
Many of the components (EGR) for instance, are failing tests left and right. They rely on vacuum from the air cleaner, but there is no vacuum coming from it, as far as I can tell. There _is_ vacuum in the intake manifold.
I did a fog test on my air cleaner and there is fog coming from _everywhere_. I can't even pinpoint it because it's so much. I did manage to see a few hot spots that def. need attention: the portion where the air cleaner meets the head, wingnuts that are supposed to keep it down and sealed, and around the intake manifold (less obvious there, but worth noting).
I guess next I will be taking apart the air cleaner to see if sealing it back up will do the trick (I'll have to do this anyway once I get the fuel cut solenoid delivered). If I see noticeable improvement there, I'll continue on and try to figure out what to do around the intake manifold.
Yep; it’s how I got that picture of the solenoid port in the original post. Why?do you have a Digital Bore scope tool by any chance ?
the wand with a small camera on end type thing
- have u tried simply taking your Finder and covering the fuel cut threaded hole while truck is running
to see if a major vacuum leal is coming from the open fuel cut threaded hole maybe ?
I would suggest going to your local Auto Zone and Purchasing a 52mm Type simple Vacuum Gauge assy
a basic one should be Under $20 , NOT a vacuum Boost Giuage , but stand alone VACUUM analog full
sweeping needle
a small piece of vacuum Hose and a T or Y fitting
i would NOT rely on a smoke test they tend to be messy and give false readings on a 30-40 year old engine
having a vacuum gauge is a invaluable way to fine tune set your ignition Timing later as well
this is My 52mm YAZAKI Vintage Vacuum Gauge iv had since high school vo-tech
it would be good measure to know what exactly your engine vacuum is right now and as u continue to make repairs and run diagnostic tests your would know instantly if u have made any corrections or improvement
I hadn’t seen this message earlier. I actually have a vacuum gauge. The only place I’m reading vacuum is the intake manifold at this point. No readable vacuum is coming from the air cleaner.
you really would not have a measurable Vacuum above the Carburetor Air horn / Base Butterflies
you would ONLY want to tap into your Intake Manifold and measure the Strongest Possible Vacuum u have
this way u know
your Goal Is ALWAYS the Strongest Possible vacuum at base idle , this is the Sign of a Healthy Happy 2F Series Engine ,
and would and should indicate things like STRONG compression , and properly adjusted Valves Etc.....
I personally Use My YAZAKI Hand Held 52mm Vacuum Gauge when i set any timing in any Toyota Adjustable Timing vehical
I Set to factory spec's such as the CHROME BB on the F/ 2F Flywheel , Using a Traditional Timing Light method
Then , Refer to the Vacuum Gauge for the Final Adjustment and final Lock Down Bolt Tweek of the distributor
Its a Fine Tuning Method That Really Does Work ...................![]()
