It's been hesitating slightly off idle for a few weeks now, but usually only when it's cold. All of a sudden now I came back from the store and put it in park and it drops down to 400rpm and is idleing fairly roughly. Enough that you can feel it in the cab with it in park/neutral and you can see the rear edge of the hood vibrating noticeably.
All within the past 10k miles/since November:
belts
O2's
vacuum hoses(all of them)
cleaned TB/intake
tuneup(plugs/wires/cap/rotor)
I'm going to be doing about 1500 miles worth of driving in the next week, so this is a bit disheartening. I'm overdue for an oil change, and will be doing it this afternoon, but I doubt that would have any effect on the idle.
BTW, it's consuming 1QT of Mobil 1 every 1500ish miles. It's burning some and leaking some. Truck smells like a two-stroke...
Suggestions?
Ary
P.S. Dunno if it matters, but Voltage, Oil Pressure, and Temp are all reading in their proper ranges...
