- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
The seal housing o-rings aren't always the source of the leak. I've had one where the bonded seal internal to the housing failed. That's the part that pushes the clutch gear and if it leaks it can't build pressure to overcome the spring force. I'm not sure which ARB model is depicted above, but the bonded seal would be #3 on that diagram. You have to separate the case to replace it. Usually less than $30 part. Just something else to keep in mind. Good luck.
Agree, it's a pain.
