identify aisan carb
okay this one stumps me
Top says Sept 1, 1971
Which would be 10/69-9/71
This is a cable operated carb
But the bottom
Is a mechanical linkage carb
3/73-12/74 federal
That being said it also has a fuel return which is throwing me off. Because that was only available after 3/73.
Most likely someone buggered the original carb top and found one off a 71 and put it on and tapped the fuel return is my best guess.
So I'd probably buy a kit for a 3/73-12/74 federal
thanks for the info
thanks for the info on the carb. i bought the cruiser with this carb on it. the po was not a mechanic type person, he did nothing mechanical to the car. he ran it like that for several years so im sure it works fine it just needs a rebuild. i was hoping it was the original carb but i guess not. or maybe part of it is. there is paper work on a rochester carb and a delco dizzy from man-a fre from the 1980s so i thought that was installed on it. so i was surprised to find a aisan carb on it. anyway i will order the rebuild kit and give it a go.
