Tanker120
- Location
- United States
Heater Blower Assy FJ40 74+
$250 + $20 Shipping (New Resistor)
Hard to find a used one that looks as good as this does, make your restored FJ40 look even better.....if that is possible..
Shell:
Disassembled
Cleaned
New foam gaskets
Additional foam gasket for some FJ40 you will need to double up were vent meats side cowl panel vent
NOTE: there maybe by chips around were the gasket goes, this is a weak part, won't be visible and will not affect operation.
All hardware cleaned, stripped and re-plated
Stamp markings reapplied with inspection ink on Motor and Shell
Fan:
Disassembled, cleaned, stripped to metal painted
Tested for 30 min. on both high and low
resistor is brand new with extension wire for some model FJ40s included
Rubber bushings replace as needed with new oem
Shell:
Disassembled
Cleaned
New foam gaskets
Fan:
