So after years of deliberating, I finally pulled the trigger on Black Friday for a complete set of 2.5 Icon Coilovers RR with CDC ($2550). It was a very difficult decision and I had many second thoughts during the 2 month waiting period. I am very serious about my Land Cruiser and wanted the best suspension money could buy for my needs (comfort, handling, high speed driving). In retrospect I believe my stock suspension was shot even though there were no external leaks.
What drew me to Icons was the high speed handling (digressive springs) and alot of positive feedback from mud members (BIG, BIG THANKS!!!).
I have never seen coilovers or used them so this is my first experience with a set. I wanted to keep stock height and originally wanted to level out the vehicle (no rake). I didn't fully realize that leveling out the rake would increase the height by 1" making it more difficult for entry for my parents. Not too happy about seeing them struggle getting in and out (makes me think of AHC each time).
This review is a bit early as I have not been able to fiddle with the rear settings- it is set to S currently and my guys and I could not find the remote resis out in the dark, muddy cornfield. (I thought the rears were supposed to be mounted in the wheel well - not sure if my mechanic improvised - he did mention that the Slee sliders changed the routing). Also, rear shocks are making my Bruiser's butt sit extra high in the air as they are not broken in yet.
On the pavement:
Car is not jarring anymore at speeds above 20-25 mph. Under 10 mph it seems much worse than stock and bounces all over the place in super rough terrain. Kind of a pain in slow, jammed parking lots that are completely torn up. At highway speeds it is amazing and smooth. I have been testing various settings and I notice the more firm I put the fronts the more comfortable it gets at high speeds. Currently running 8 on the fronts, drove 150 miles @ 80+mph and I am not tired, nor is my back or legs hurting. Previously, my body would tire from the bumpiness. There are still minor bumps but overall no jarriness. I thought it might take out even the minor bumps but that might be wishful thinking. In the beginning I did feel every crack and crevice on the road but not feeling it soo much now.
Offroad:
Chicago warmed up this weekend and so the mud was extra muddy. We drove through some cornfields at 40 mph (front 8, rear S). I wanted to firm up the rear to see if we could go faster but the mud felt like we were sinking if we stood still in it. I plan on trying this again soon once I talk to my mechanic about adjusting rear settings.
Handling:
It is beyond amazing. U-turns are now a one lane affair (used to take me more than 2 lanes). I am pretty sure turning radius is less than my 2001 BMW 750IL. Also, before at speeds over 80mph I felt like there wasn't proper control and would hardly go higher than 80mph unless out in the open. I am still getting used to the car being 1" taller. It's lost a little bit of the aerodynamic feel of nimbly cutting through the wind but it corners much better now. I am more confident driving and adjusting the settings feels like it changes the tightness in the steering wheel. Softer I set it the looser the steering wheel becomes. The handling feels much more crisp and sharp and body roll is greatly, greatly reduced.
Comfort:
I realize comfort is all in the rear spring now. Since I am using stock rear springs, ride is plush. I wouldn't call it super plush but its good especially at speed - much better than stock. I am still trying to see how much of a difference adjusting the CDC valve makes. At first it didn't feel like much difference between settings from a comfort perspective. I noticed it mostly at high speeds. But starting to notice it more now after putting 100+ miles. Not sure if I should change rear setting for highway, S is supposed to be softer than stock.
Braking:
No more nose diving under heavy braking. Much more controlled, probably due to being level.
Tire Pressure:
I have kept it at 42 right now but read a different review that found 38psi better. May try that soon.
Armour?
Not seeing the pavement move as I throttle makes me think I am moving slower or maybe I am fighting more wind resistance? Either way I have been throttling more. Its making me think of putting on the front deluxe ARB winch bumper I have lying around. Only reason I didn't install it is because I didn't want to increase drag. But it may be lost now since I am 1" taller? How much worse can it get? I don't like the idea of 'strapping a fat chick on the bumper' as some other mudder put it. It sounds like it might mess up handling.
Final Thoughts:
My initial impression was handling and comfort were going to be better than what they turned out. They were good but not as much as I was wishing for. I was wishing for the impossible - Super Plush and razor sharp handling. I would say it is plush and has sharp handling. Definitely a great improvement and probably the best 5800 lbs SUV is going to get.
Would I do it again?
Most likely, I think this set was perfect for me other than having to lift 1" in the front. I might have tried going a different route but don't think I'd get the satisfaction I am getting from the Icons. I imagine in order to fit the larger piston they had to increase travel by increasing vehicle height. The CDC option has been nice but not sure how much I am going to fiddle with it.
On the pavement:
Offroad:
Handling:
Comfort:
Braking:
Tire Pressure:
Armour?
Final Thoughts:
