Let me try this a different way.
Yes you have a geometry issue as well as a travel issue. It doesn't matter who makes the shocks. When I built the suspension on my TJ, I copied a friends configuration and pulled a Bilstien apart from over extending. The problem was the "experts" told me that the shock was strong enough to limit the travel. They were soooo wrong. I installed limit straps to keep this from happening. The problem here was, no one could see what mine was doing or how I was doing it from a forum.
If your axle swing puts enough angle on the shock mount, obviously something is going to give.
This was a lesson I learned about 20 years ago. Since then, I now cycle my suspension and double check my angles.
Spending my whole life as a tech taught me, you cant get all the answers over the phone or in this case the internet. You can get ideas/opinions or peoples experience. That's it. If you don't get the correct answer, its not the fault of the tech guy or the forum. If no one else has this issue, you need to diagnose it yourself which could mean learning more.
Your bending things, that's geometry. Have you actually cycled your suspension, measured how far it can go without a shock and looked at the what the shock angle will be when you did this? Is the top of the shock hitting the body? That will be obvious by the scraping. Are your bushings allowing more twist? Which way is the stud bent? Did you install the upper bushings correctly so the thread is not contacting the mount. Is the shock mount slightly bent, allowing the top to be closer to the body?
These are things I think of when I read this. If I actually saw and diagnosed this, I would see things I didn't think to write here.
