I was just lettin you rant to see if you would bring it , you did ,that was funny. Yeah just run it , duh, My fluid had little stuff but no bfd. I got leaks confirmed and verified at the idler , speedo , A/A mount , fawk , everywhere I looked except the e-brake and rear out put and front output so you know what , that's right folks fawk it. I think the A/A mount interferes with the new cases at the rib in the casting thats at 5 o'clock position. I will clearance it soon. I also discovered that when bolting t-case in we did not notice passenger side motor mount was just hanging in mid air about 1 in. above the rubber pad.( A/A style mount ) . Lower pad failed and allowed bolt to move up . WTF , can't anybody do s*** right , even me. it never ends. I now realized why PO had a 3/4 in. stack of washers under the driver side rear A/A mount ( kinda like puttin a book under 1 corner of table)... I quickly replaced failed rubber , put a 1/2 of nice pimpin washers under each mount and tighten er up. Maybe the starter won't go zzzzzziiiiinnnnnggggg every time it starts , damn thing sounds like a blower or something then it starts and people are like so what was the big noise , .. I am not mia . I just got done puttin my disc's on the front and let me tell you , the boy's at JT's r&d department prolly are glad they were not in Cali. this weekend. I fixed motor and t-case mounts , installed brakes , drilled , ez outed and re tapped all my f-ed up hub bolts( 6 ) , drilled and replaced all 4 shear pins which were previously not there or busted. Put soft top on . Installed new hardware on rear trac bar to prevent constant loosening of some bolts .
Cool thing is I don't have to use the 1/4 in. spacers with the new discs , they clear the tie rod end.
Bad parts , Jt's kit has you grind down hubs around peremiter to fit inside new rotor ( one fit and one I ground ( easy )) Had to remove steering stops , calipers don,t contact brackets , meaning all the stock disc brakes I've seen the calipers ride right between the fingers of braket and are close so when you stop on it the caliper is up against bracket not just held by bolts. The bolts they supply are way to long and not drilled. I reused stock and wired em. Installed windshield hold downs and pads on hood, did not get my heater in tho , dam it . What did you get done , oh yeah , beware people here come the picks of this weekends compost wars , and the stump climb , and can you for the love of God take those flapper shackles the heck off the 40 and give em to some mini truck guy. I get my birf's back from the doctor soon.
