Hi gang - I just posted this over on r/LandCruisers but would like to post it here for the real OG Land Cruiser experts.
About a month ago my 1999 with 230k miles almost left me stranded at a trailhead a couple hours from home. When I turned the key it cranked but never fired up (see first video below). After a couple attempts it started and I could drive off. I took it to AutoZone and the battery and charging system both passed their diagnostic tool but I got a "Bad Starting System" result (see picture).
Since then it's mostly been fine - maybe a little slower to start sometimes but nothing egregious. Today I finally caught it acting up the same way. This first video shows the engine cranking but not starting (at least that's what I think of when I hear "cranking", please correct me if I'm wrong)
and this second video is a little more difficult to read. I took it after the first one when I'd taken the key out of the ignition and everything should be dead but you can still hear some electrical whirring. The first loud *pop* is from the speakers and is a weird issue where if I put the key in to turn on the electronics without starting the car I'll get that pop a few seconds after taking the key out - it doesn't do it if I've stopped the car after it's been running. The second *click* is whatever electrical noise cutting out. After that I tried to start it up again and it worked.
The electrical whirring may be completely unrelated - I don't recall hearing it when this happened at the trailhead last month. But otherwise it was the same story - cranking but not firing, try a couple times before it fires up on the third or fourth attempt.
