Hzj77 vs hzj76
New Hampshire
Looking into getting a 1980-1999 70 series. I started looking at 90s american models (mostly 80 series) and was disappointed to find almost no manuals. I had started looking at 80 series because I just assumed an import would be at least $40k. Eventually I stumbled into JDM imports. I have no qualms about the right hand steering, I lived in Japan for a few years and drove manuals and it never bothered me.
I know I want
- hz engine
- manual transmission
- 4 (technically 5 counting the rear) doors to fit 4 people
- disc brakes (which I believe are stock in the 70s)
- hand lever e-brake (again I believe this is common on all 70s)
Lesser wants
- ability to turbo it
I don't see a whole lot of after market support/parts for the 77 series, most sites will list the 76. I know there's some cross compatibility between the two because of their similarities.
I like that older 76's barely have an ECU if at all, I know basically all 77's just run without it. I like the idea of front and rear leaf springs, but I also own an old pick up with the same set up and it feels like a beast to drive but worry about getting a TBI when I hit a bump cause man does it rock me around the cabin. I love the ruggedness of leaf spring suspensions, but know coils are much more comfortable.
I also know that both are generally "under powered" and would like to eventually turbo it. While I know you can turbo anything with enough money, I've read that the 77 series has a smaller engine bay and doesn't have any(that I've seen) turbo kits. Plus with the need to have a cooler for the turbo I want to check all my bases before I spend 20k+ on a vehicle.
Any help making the decision would be much appreciated! I mostly worry about getting a 77 and seeing a cool upgrade and buying it only to find it doesn't fit and having wasted money, or spending more money and time to make it fit.
I believe, perhaps incorrectly, that the HZJ77 and the early HZJ76 are for the most part virtually identical.
As Juan pointed out, and I overlooked, was the differences in suspension and electrical components.
Hello,
76 Series trucks are 12V and have a front axle with coil springs. 77 Series are 24V and have leaf springs all around.
JDM 76/77 Series have both auto and manual transmission. Watch closely before you buy.
Yes, 76 and 77 Series do not have an engine ECU. JDM trucks do have emissions control equipment, though, namely EGR. Some owners choose to delete it.
The 76 Series remains in production. So does the 1HZ engine.
Engine bay size is the same. The 78 Series Prado is the one with a smaller engine bay. It is different from the 76/77.
From the windshield back, few things have changed over the years.
Some 77 Series parts are becoming scarce, especially electrical components. However, other parts can be replaced with newer model 76 parts.
Regarding engine power, a properly tuned turbo and an intercooler can help. The 1HZ engine is an indirect injection engine that does not like additional heat very much, hence the importance of proper turbo/intercooler setup and tuning.
Hope this helps.
Juan
Yeah I've seen the same thing. I just worried that it's a generalization and I'll see some roof rack or bumper and think "oh yeah it fits a 76 should be good" and then dropping several hundred, if not a couple grand, only to realize it doesn't fit.
I know for electrical I'll have to install a 24→12 converter for pretty much anything I add. I'll probably install a 12v fuse box for everything as well just to be safe.
I appreciate the info, I have probably been over thinking it, but I fear buyers remorse. Or more accurately getting balls deep in a project only to find the thing I want(or got already) is a bunch of money and having my car sit while I wait for pay checks.
Juan - Asking out of ignorance, but wouldn't the "wide nose" 2007/later 76 Series have more room in engine compartment due to wider frame/front clip?
Cheers!
There are a number of 77 Series (and a few early 76 Series) owners on ‘MUD and I’m not aware of anyone expressing regret in their purchase. I myself, owned a 77 Series for a number of years and really liked it.
If ya don't mind me askin, why'd you get rid of it? I'm very much a "I'll own this car till me or it dies"
Hello,
Hope this helps.
Juan
Regarding the turbo, I've heard to get an intercooler in a 77 it requires a lot of extra work and money. Not as simple as other 70 series. Maybe I assumed it was because the nose is a bit narrower, which made me think that the engine bay was smaller.
I'm glad to hear there's a lot more parts and accessory compatibility. Thank you for the info!
That's true that's true. Seems like everyone hear loves their 77. I'm hoping to join the party in the next couple of months, gotta wait for some financial stuff to smooth out before I make the jump.
Don’t mind at all. The short answer is that I’m STUPID. I have a terrible habit of finding what I think is the PERFECT Land Cruiser , spending piles of money on it to meet my imaginary needs, and almost immediately, I start thinking there is something even more cool out there. I don’t recommend my business model to anyone. 😁
P.M. sent …..
If you are getting the 77/76 as a family hauler, I think you might be disappointed. I own a HZJ77 right now but I didn't buy it to be a family hauler (no wife or kids).
Cheers!
Hello,
Yes, they do. There is some more transversal space.
Overall width of the front clip did not change. The engine bay gained some more space on the sides, where the narrow nose fenders used to be. Interestingly enough, parts like the battery tray still fit older model trucks.
From the windshield back, there were no changes.
It is possible to install the newer front clip on a pre-2007 truck. All you need is the parts.
Toyota widened the front part of the frame to make room for the V6 (1GR) and V8 (1VD) engines.
Juan
P.M. sent …..
God I feel that. Runaway wants.
I went camping and the camp ground manager came over and started talkin with my buddy and I. I told em about some of the stuff I wanted to do to my car. He said "your wants are showing.... whenever my daughter starts listing all the things she wants to spend money on, I tell her her wants are showing." And it has helped me reduce my spending.
I have really liked 90s vehicles for as long as I can remember, and I've loved diesels ever since my first tractor ride. I am bad about starting a project and then taking months to get back to it.
Hello,
Juan
I like the sound of that! Glad to hear it's very compatible.
Just to confirm what no one else has said here (and you keep mentioning money/finances, etc.): These trucks--especially non-US gray market iterations-- are **EXPENSIVE** on the back side. Keep that in mind when staring at the 1am drunk boner you got for buying a rad truck.
:lol:
I ask out of ignorance.
What is it that makes them expensive? I've been looking at parts and nothing seems too crazy. I worry about like a part breaking, having a dead vehicle, buying 1 online thinking it would fit, only to find out it won't. Or buying a bumper and realizing it's actually not compatible.
From what I've been seeing, the vehicle itself hardly breaks. It's just people love to mod them and sink their money in with that. I keep reading how bullet proof the 70 series are, I know everyone seems to love the 1HZ engine, heard that the HZJ77's transmission and drive train are a lot beefier than it needs to be. And that the only real "weak" point is the front axle. Which is still strong, just weaker than the rest of the beefy vehicle.
Hello,
JDM 77/76 Series were regarded as work vehicles in Japan. Some were treated accordingly, some were not.
Yes, 70 Series are overbuilt, but they are not immune to abuse or half-assed modifications. If treated properly, they can be very reliable. Proper treatment involves spending to get things right.
It is important to keep in mind that it is an old truck that may have lived a hard life. Baselining and further maintenance will cost money.
Most US mechanics and shops have not seen a 70 Series and may not be willing to work on one. Those who do charge accordingly. Yes, 70 Series are designed to be repaired one system at a time, but that implies time, money and parts. Some procedures require access to a shop and its tools, even if you are to carry them out yourself, and that comes at a price.
Toyota parts are not too expensive. They are not cheap either. You need to fill an HS-7 form to obtain access through Toyota US. You can also source parts from 'Mud vendors or overseas suppliers. Regardless of the source, delivery can take time.
Make sure the truck you get is in good shape and get ready for proper baselining and further maintenance, as well as gremlins (they are always lurking.) Make sure your wallet is up to the challenge.
Remember: do not spend money you cannot afford to lose.
Juan
I guess the question becomes for you: are you mechanically inclined or know how to work on vehicles? Or, more specifically forklifts with an AC compressor?
IE: are you doing the work yourself (meaning: labor is $0 dollars beyond your time) and you are researching parts and doing everything yourself based on public information that you glean/research (highly recommend against using chatAI bots for this work).
Or are you trusting a mechanic to do the work for you?
These are two very different dynamics. If the former, then 7x trucks are probably no more cost intensive than owning a 1960’s/1970’s American muscle car that a middle-aged white man/ or a retired dude buys because he can’t stand his wife and needs a distraction.
If the latter, owning a 7x approaches the cost of owning a B-17 bomber or a Model T you are restoring or a MKIV Supra; there is significant relatively of “cost of ownership” involved with Land Cruisers.
Everything is based on money.
Since January 2026, I have had 12 7x trucks come through our shop and every single one of the owners had no idea what they were getting into when they bought the truck. They bought “cool”, “rad”, “JDM.”— usually after they found out they won an auction on BAT at 2am pounding JagerBombs. Then the reality hit that they bought a POS.
Seems like you are doing your homework, don’t fall into the above trap. Sometimes a Prius is just as good to get you from point A to point B.
Just saying.
Also: **and** everything @JuanJ mentioned above for context.
