I don't have an HAC anymore (altitude compensator). They only work to about 3000m as much as I know, after that they just make things worst and you need to open it and block it somehow. From other travelers I heard the regular 1HZ performs terrible at 4000m or 5000m! But I never bothered with the HAC since I installed the Turbo and put a boost compensator instead of the HAC for this trip to south america!
Ok, I am in Quito at a garage... the guy is an ex race car mechanic. He is not a Diesel specialist, but he has lots of experience and good connections.
The radiator bottom tank was removed to inspect, looked all pretty clean, but he re welded the bottom and fixed that leaking spot on the bottom tank I had. He still rodded the radiator to be sure.
The mechanic said not to bother with that heavy duty radiator, it should perform very well with my car...
We washed it outside, there was still some mud and dirt in there!
Coolant was tested and it's little bit alkaline, so the head should be fine, although I have an oil leak since 100'000km on the rear of the head, probably from the camshaft oiling passage. That's why I wanted to have the coolant also tested. (was hard to find this PH paper here!)
I installed a new Toyota water pump. The old one was still ok, but the bearing was showing a little bit of play. It's just too much work to redo this anytime soon so I replaced it.
The bottom hose is very soft, since we couldn't get a good fitment we installed a coil inside to help against collapsing, although I don't think this was the problem. But just to be sure. I will order a new one in Europe.
Timing belt is new now (old one was 110'000km old) and new idler & spring. The old one had some rust spots, but looked otherwise fine.
Thermostat looked used but opened at around 75-80Celcius and at 85Celcius (the water would already boil here in Quito!) I measured 10mm opening, so it's within Toyota specs!
NOW, the injectors! We removed them and they were FULL of carbon! So bad, that I hardly could remove the brass washers! We sent them to test and the guy said they are totally shot!
They got only 70'000km on them since they were rebuild in Vancouver, Canada. The mechanic said the Diesel in this countries is terrible plus the Turbo pressure surely won't be nice on the injectors. Not sure about that. Is that normal after 70'000km? I installed now spare rebuilt ones I had still from Canada.
I just checked also the injection timing. 1.08mm! Specified is 1.03-1.09mm, so I am at the max end as the Diesel guy in Vancouver told me to set it! We set it 70'000km ago in Vancouver at 1.09mm, so it just changed 0.01mm, I guess that's good.
I hope this was the reason, the very bad injectors surely generated extra heat, the little bit dirty radiator and who knows what else...
Let's see tomorrow, will do some test drives tomorrow!
