HZJ73 Clutch Availability
Renosherrifs1
Hello, I need to do a clutch for the cruiser I just purchased purchased below. Do you know which Clutch kit I should look into that might be in stock? Only place I've found avaliable is Ebay, and not very confident with that.
Frame-HZJ73-0001986
Engine-1HZ
Model-80HZ073V-MES
Frame-HZJ73-0001986
Engine-1HZ
Model-80HZ073V-MES
If you plan to turbo it then go with a upgraded clutch , if not stock replacement will be fine
