SOAZtim
Hobo
- Location
- United States
SOLD
This is a subtank from a 105 with straps which is related to the 80 series you could say. Can be used on an 80 series like George did. Here is some info on this model tank from his website:
"The 105 subtank appears to be slightly larger.
- The 105 is advertised to be 65 liters (approx. 17.2 U.S. gallons) as compared to the 50 L (13.2 gal) for the 80 series tank. This may not be correct though, since all Australian references to the 105 series state the subtank to be 50L in capacity.
- The 105 tank support straps are too long.
Designed for mounting on the 105, the support straps are approx. 1-2 inches too long for the 80. The original 80 straps are contoured for the 80 tank, and will not fit the contours of the 105 tank, so the 105 straps appear to be the only solution but require some creative modifications to mount the tank securely." Check out his website for info: Auxiliary tank
