Morning, hoping for some guidance. My '98 100 (LX variant) is leaking suspension fluid from what looks like the passenger side rear strut. AHC flashes "off". This started Friday when I "lifted" the AHC to the highest position as expecting flooding with Hermene on the way. Large pool of fluid underneath when driving out off car port a few hours later. Assume added pressure of the "hi" setting did it.
I cannot get under the vehicle (rear has lowered almost to the stop) to actually see where the leak is originating but I believe it is the supply line from to the strut. Reason I think it is the supply line is that torsion bar is covered in fluid and dripping from there. If it were the actual strut wouldn't the fluid drip be further to the rear of the truck at the tire?
Anyway, I have two cans of AHC fluid on order. My plan was to fill the reservoir and see if it will be enough to raise the vehicle to drive height.
Does this "sound" like a break in the supply line or a failure in the strut? Does anyone have a photo they can post that "shows" the orientation of the supply line to the strut assy? I've looked at the shop line drawings but can't determine the relative position.
Thanks so much
Thanks so much
